on 05-05-2022 02:49 PM
Hello everyone, hope you are all splendid.
I really need some assistance as I'm near the end of my tether.
I've been offline since the 13/04 and after numerous support calls it was ascertained that a problem existed with the exchange. Cue friendly Openreach chap to tell me it has been fixed their end and I should be good to go. But sadly, still no connectivity. After another protracted battle with Tech Support they said the problem is likely with the wiring into my house, another Openreach chap got in touch and this time came into the house, did his checks, changed the master socket and said the problem is likely with the router.
Ring TalkTalk, attempt to explain, they send a new router and to absolutely no one's surprise, it does not connect, instead flashing amber/white upon boot and then a steady amber light.
I've done more soft/hard resets, reset to factory defaults than I can keep count of. I'm getting this close to cancelling and going back to dial-up or two cans and a really long piece of string.
If anyone can help me, it would be appreciated.
Cheers
on 11-05-2022 02:29 PM
OK thanks. I've sent you a PM to confirm some details so that we can look into this further
on 11-05-2022 01:22 PM
on 10-05-2022 10:39 AM
Yes, no problem 🙂
on 10-05-2022 10:28 AM
@Chris-TalkTalk - I won't know until tomorrow as I'm away with work. Can I let you know then please?
on 10-05-2022 09:39 AM
Thanks for the information. Is your broadband service working now?
on 09-05-2022 04:09 PM
Hello @Chris-TalkTalk,
Had an Openreach engineer get in touch today and here is what he surmised:
* Telephone landline has been reconnected
* The broadband service is currently associated with plusnet
* He rang up talktalk to enquire as to why the service isn't with you and he was told it will not go active as there is an outstanding balance on the account.
* As alluded to on another ticket, that bill has now been settled and we have signed a new contract.
Can you let me know if the above makes sense and if everything is now ready for us to be reconnected?
Cheers
on 06-05-2022 03:13 PM
No problem, you too 🙂
on 06-05-2022 03:12 PM
Thanks for your help @Chris-TalkTalk, have a good weekend!
on 06-05-2022 03:10 PM
Thanks for trying that. Line test is also picking up a potential issue so I've logged this to Openreach for investigation. Openreach will investigate and may contact you directly if they need to access your home
on 06-05-2022 02:09 PM
Hi @Chris-TalkTalk,
Apologies for the delay. We got a landline telephone, plugged it in and nothing. No dial-tone, nadda.
What's the plan of action now?
Cheers
on 06-05-2022 08:58 AM
Sorry but could you start a thread/topic in the billing section and we'll be able to help 🙂
06-05-2022 08:56 AM - edited 06-05-2022 02:12 PM
edited - OT post
on 06-05-2022 08:44 AM
Thanks. If you've tested at the test socket then we just really need to test with a telephone if possible, to see if the voice service is working
on 06-05-2022 08:40 AM
We have 2 sockets, one in the bedroom that we've never used and the master socket downstairs. The master socket (model: openreach mk4) has only the rj11 cable plugged in.
I've tried the test socket with a filter, another rj11 cable in case that helps troubleshooting.
Cheers
on 06-05-2022 08:22 AM
OK thanks. Line test is clear, How many telephone sockets do you have? Do you just have the router connected to your telephone socket(s) at the moment?
on 06-05-2022 08:17 AM
Hello, we don't own a landline telephone, we are hoping to borrow one from a friend later today. In the meantime, are there any checks etc, you can do your end?
Cheers
on 06-05-2022 07:17 AM
Hi allied_biscuit,
I'm sorry this issue is taking so long to resolve. Is your telephone service working OK, is there a dial tone?
on 05-05-2022 04:06 PM
Hi @allied_biscuit you are a very patient soul,congratulations. The team here will get to the bottom of this for you and your post has been escalated for their attention. You should hear back soon.
