Steam won't connect
1 REPLY 1
Glynn2
I can access my router dashboard.
I can set up a port divert using the IP address of my MAC.
Still Steam is "offline"
Can anybody help?
To adjust your SCAM protection level...
Please try the steps below to disable scam protection on your line:
Log into
MyAccount
then select...
My Services
followed by
View HomeSafe settings
Choose OFF and confirm when you see the pop up window
This should help with access to video conferencing etc.
