Strange router behaviour
Clive1975
Message 17 of 17
Hi. Our router seems to be on the way out, it’s can be fine for days then randomly will drop around 80% of the wireless connections, just leaving the wired ones and a few random WiFi items connected, even though the devices say they are connected to the router, they have no throughput. A hard reboot sorts it, but it’s annoying. Can a new router be sent to see if that helps?
thanks
16 REPLIES 16
Message 1 of 17
I've turned off wifi optimisation for the router as this can cause the wifi channel to change remotely.
see if this helps.
Message 2 of 17
was going well until yesterday evening when again it drops most of its connections and refuses to reconnect any it has dropped. Three screenshots attached show the router with only a few wired or wireless connections, the last is straight after a reboot when all back fine.
Its frustrating 😖
Message 3 of 17
Thanks for the update and please let us know how the connection compares over the next few days.
Message 4 of 17
Router arrived and connected this morning, all smart plugs etc connected straight away so as long as this one does not exhibit the same issues as I had at the start I am happy!
thanks
Message 5 of 17
Hi Clive
The Sagemcom router is on its way and a returns bag for your current router.
Please allow 24-48hrs for this to arrive. Let us know how the connection compares.
Message 6 of 17
Hi.
App up to date too. Don’t think it’s the plugs as when I plug the old router in which had the WiFi dropping issues it picks up the plugs and I can set them up fine.
If I can have the sagemcom to test that would be great, thankyou.
Message 7 of 17
Hi Clive
Has the app been updated too? (any new updates)
Would you like me to send a Sagemcom WIFI hub to see how this compares?
Message 8 of 17
Hi.
Yes, router was new anyway but reset made no difference. Plugs reset too. It’s very odd as whenever we have swapped providers or had our own router once they have the new details they all connect immediately, the app sends the WiFi details to the plug using the details it’s using to connect itself (all 2.4g) so can’t input incorrect passwords either.
Message 9 of 17
Hi Clive
Have you factory reset both the plugs and router?
Message 10 of 17
Hi. Yes, with the Huawei hub just sent.
Message 11 of 17
Hi Clive
Sorry for the delay.
Just to confirm, is this happening with the Huawei WIFI hub?
Message 12 of 17
Hi. Yes tried setting a fixed channel rather than use automatic but no joy🙁
Message 13 of 17
Have you tried changing the channel kn 2.4Ghz band. Food for thought though if you have the Sagemcom this has WIFI Optimzation feature where it automatically changes the channel and can only be turned off by TT.
Steve -
Have you tried turning it off and on again!
Message 14 of 17
Hi.
New router arrived, however it seems to have a bug somewhere as it won’t let any of our smart plugs connect, they are sonnoff s26 plugs. The old router had no problem, and when I plug it back in they all spring back to life. Have reset to factory settings the plugs but still they just can’t see the WiFi. Have also split the 2.4 and 5G networks as they only work with 2.4g.
everything else connects fine, but if I can’t use the plugs it’s not much use sadly☹️
Message 15 of 17
Hi Clive
I've ordered a replacement router for testing, please allow 24-48hrs for this to arrive.
Ste_Nix14
Message 16 of 17
What hub do you currently have?
Do wired devices remain connected and able to access the Internet when the wireless devices can't?
Steve -
