26-05-2022 07:28 PM - edited 26-05-2022 07:36 PM
I have a TalkTalk WIFI Hub supplied a few years ago and a Smart TV with IPlayer, Netflix and Amazon Prime on it which I stream via the WIFI chip on my TV connecting to the router. I am on Fast Fibre 35.
Over the last year or so in the evening I keep getting problems of it disconnecting when streaming these services. Weirdly, rebooting the router solves the problem completely but it reoccurs the following day. etc etc.
I have just checked my speed and connection via the TalkTalk Services page on my account and it says there are no problems.
Any suggestions? Do I need a new router or a new TV?
on 27-05-2022 11:50 AM
No Problem 🙂
on 27-05-2022 11:49 AM
Thanks Karl
that should at least eliminate one of the causes. Saves me messing around with the box and router now which would be a fiddle.
If I'm not in tell them they can put it in the front porch .
Might also be the TV as its one of the earlier Smart TVs. and I suspect the memory and WIFI chips in these older versions may not be up to modern day streaming rates particularly in the evening when loads are high.
Many thanks to you all for your prompt responses.
27-05-2022 11:24 AM - edited 27-05-2022 11:26 AM
I have taken the faceplate off. Here is a picture of it. Where is the test socket?
on 27-05-2022 11:06 AM
Hi GEG63
I've a new router on the way so we can rule this out. Let's see if this helps.
Also, when testing with the new router, if the connection drops, look at the home plugs in the sockets and see if the lights on these remain green, or go off or red etc.
on 27-05-2022 11:00 AM
Also to add, in case it's relevant, the TV is connected to a TalkTalk Box via a HDMI cable and the box is connected to the router via power sockets (cabling and adaptors supplied by TalkTalk) from the living room to the Hall where the router is located.
I also have an old DVD/Videotape player/recorder connected to the TV by a HDMI cable although its not usually switched on.
on 27-05-2022 10:55 AM
Hi GEG63
Thank you. There should be a test socket underneath the faceplate if you remove the 2 small screws.
Would it be ok to connect the router and filter at the test socket?
27-05-2022 10:49 AM - edited 27-05-2022 11:09 AM
Hi Debbie here it is. The green wire goes to a small old land phone I have in the bedroom.
on 27-05-2022 10:19 AM
Hi GEG63
Would it be possible to post a photo of your master socket on this thread?
on 27-05-2022 10:16 AM
Hi Michelle
I haven't noticed whether the mobile internet was disconnected when the streaming sticks. I will look next time it happens. There is no crackling on the phone. Calling seems OK.
I also very occasionally get situations when the internet disconnects completely during the day for my PC, Laptop and mobile then reappears after a few minutes or if I elect to reboot the router.
The router is in the Hall downstairs and is connected to the box where the phone line comes into the house in the front bedroom via an extension. The box was replaced by Openreach a few years ago so its pretty new . Don't know whether it has a test socket.
on 27-05-2022 07:21 AM
I've run a test on the line now which has detected a potential fault. Are you experiencing any noise on the voice service? Does the main socket have a test socket please?
on 26-05-2022 10:12 PM
When the TV loses its connection does your mobile also lose its connection, or does the mobile keep working ok ?
on 26-05-2022 09:45 PM
It remains white. I usually only have the TV and my mobile connected to the router internet.
on 26-05-2022 09:22 PM
Hi @GEG63,
What does the LED do on the router when you have these issues, does it remain solid white ?
Do you have other devices (desktops, laptops, phones etc.) that also use your TalkTalk connection, if so are they affected at the same time, does the problem affect devices that are connected both by wire and wireless (if you have both).
