on 29-06-2022 07:41 PM
Is it possible for profiles to get stuck? I'm on the fibre65 with a sync speed of 60000 but only an actual speed of 44000. Is it possible to get this raised?
This is connected to the test socket.
on 13-07-2022 03:25 PM
Hi ma9mwah,
I've run the test again, still showing interference but the error count is generally low. I'm not really sure what else to suggest. It would be good if you could leave the setup as it is for 48 hours to see if DLM moves you to a faster profile but I understand this may not be convenient
on 13-07-2022 09:40 AM
OK thanks, I'll run the test again then later this afternoon 🙂
on 13-07-2022 09:39 AM
Yes, I'll be able to keep it like this for most of the day.
on 13-07-2022 08:45 AM
Line test is still showing interference, would you be able to leave the setup as it is and I'll check again this afternoon?
on 13-07-2022 08:38 AM
Thanks, I'll run the test now
on 13-07-2022 08:34 AM
Telephone and power adaptor have been unplugged for testing
on 12-07-2022 04:17 PM
Would you be able to temporarily disconnect the telephone and power line adapter and we'll run the test again? Could you do this tomorrow and bump the thread when you've done it, we'll then run the test again
on 12-07-2022 03:43 PM
Yes, plugged directly into a double wall socket
on 11-07-2022 08:15 AM
OK thanks, so just to confirm, it's a double wall socket?
on 09-07-2022 03:39 PM
Sorry for the late reply, just got back from holiday.
It's not on a extension lead, but it is plugged into a a double socket that also has a powerline adaptor in it, which then has the telephone base unit plugged into it.
on 04-07-2022 08:56 AM
Hi ma9mwah,
Is your router situated close to any other electrical devices that could be causing interference? Is it connected to a multi-socket electrical extension lead shared with other devices
on 04-07-2022 08:36 AM
I've moved it as far away as I could.
on 04-07-2022 06:26 AM
I've re-checked and interference is still detected. Can I just confirm, did you have a chance to move the phone away from the router?
on 01-07-2022 07:54 AM
Hi ma9mwah
It's worth a try to see if this helps.
I can also check the connection stats again on Monday to see if interference is still being detected.
Thanks again.
on 30-06-2022 02:43 PM
I can move it to a couple of feet away, but then I'm limited to where I can place them.
on 30-06-2022 11:22 AM
Hi ma9mwah
Would it be possible to move the phones away from the router to see if this reduces the interference detected?
on 30-06-2022 10:27 AM
It's on the same table as our dect phone.
on 30-06-2022 08:30 AM
Hi ma9mwah
Your current sync speed of 44mb is within the range for your line.
I can see some interference on the line, is the router located near to any devices that could cause this, such as wireless phones etc?
on 30-06-2022 08:22 AM
The router is already plugged into the test socket
on 30-06-2022 08:21 AM
Tried that this morning. Still connected at 44000 when switched back on
