Stuttering
Nacrosis13
Message 9 of 9
Good Morning,
We are getting a bit of stuttering while we watch programs on either Amazon/Netflix/Disney+ it does get a bit annoying, is there anything you can do or I can do this end.
Regards.
Nacrosis13
Amateur Everything and Founding member of the grumpy old Men`s club.
8 REPLIES 8
Message 1 of 9
Glad I was able to help.
Message 2 of 9
Morning Karl,
Well it seems that may have fixed the problem, there was little to no stuttering plus the tablets are getting to the websites quicker.
So I think the answer was a new router.
Thanks again.
All the best.
Nacrosis13
Message 3 of 9
Morning Karl,
Received the router thanks, installed this morning, will check it out with the TV over the weekend and let you know how it goes on Monday.
Have a good weekend.
Regards.
Nacrosis13
Message 4 of 9
No Problem 🙂
Message 5 of 9
Thanks Karl, I wondered if it could be the router it is and old one now and I know the tablets have been getting a slow response.
Will give you a shout once connected and tested.
All the best.
Nacrosis13
Message 6 of 9
OK, so this would be a wifi issue rather than a connection issue, so I'll focus on that side of things.
Looking at your wifi, there are high errors on both the transmit and receive to the router.
I've a new router on the way to you and we can see if this improves things.
Message 7 of 9
Hi thanks for getting back so quickly, yes I have a AmazonFire Stick attached to the TV, do you think that could be causing the issue?
House all WIFI via Router.
Nacrosis13
Message 8 of 9
Tests are clear, sync speeds look fine.
Is this with devices connected via wifi ?
