01-09-2020 03:19 PM - edited 02-09-2020 02:24 PM
A couple of months ago I upgraded from normal fibre to superfast. For a couple of weeks it was excellent, speeds of 130-140 Mbps. For the past few weeks the desktop has been slower than my old standard broadband was and sometimes even as low as 1.5 Mbps, but my phone is more or less always at the 130-140 Mbps. I`ve installed a new network adapter because my old one was probably around 6 years old but it`s made no noticeable difference.
Any ideas?
on 04-09-2020 09:07 AM
No problem 🙂
on 04-09-2020 08:59 AM
on 04-09-2020 08:10 AM
Hi steve,
Ok thanks for confirming and please let us know if you would like us to try and offer some advice on this.
on 03-09-2020 06:54 PM
on 03-09-2020 09:09 AM
Hi steve,
Thanks, is it just the desktop computer that is experiencing the slow speeds? Is this connected using any powerline adapters?
on 03-09-2020 08:51 AM
on 03-09-2020 08:41 AM
Hi steve,
Thanks for the update. The wireless speeds are a lot lower than the wired speed. Do you see the same wireless speeds on different devices?
02-09-2020 07:15 PM - edited 02-09-2020 07:43 PM
Strange. I powered down the router and Openreach box for 30 minutes, tried checking with Talktalk`s speed checker and it gave me "Site can`t be reached" so I tried Speedtest.net and that loaded but couldn`t connect. I finally got Bing`s checker to work and the result was 10.82 Mbps.
I`ve used Talktalk`s checker and Speedtest previously and they always work.
Edit: I can run a check on my phone with both Talktalk and Speedtest.net with no problem.
Edit 2: 😁 All the above are with Chrome, I tried with Opera and they work no problem, result is 18.44 Mbps wifi and 151.56 Mbps wired, that`s with Speedtest.net.
Talktalk:
Wifi
We've finished measuring your speed, and here are your results.
19.6 Mbps
Your average download speed
29.6 Mbps
Your average upload speed
Wired
151.6 Mbps
29.5 Mbps
on 02-09-2020 02:23 PM
Thanks for the reply😉
If I do a powerdown of the router and the white box underneath it, usually for a minute or so it does get faster but I will try a full 30 minute switch off and update.
on 02-09-2020 11:09 AM
Hi stevelane
I've completed a line test which hasn't detected any faults and your line is in sync at 160mb.
Please can you power down the router for a full 30 minutes and then run a speed test following this?
