Sync speed dropped a week ago and hasn't recovered
zofbtb
Message 19 of 19
My son unplugged the router when doing the hoovering last week. The sync speed dropped to 55Mbps from just over 60 and is still at 55 today.
Would also be good to get the latest firmware, I'm on SG4K10001E00t
18 REPLIES 18
Message 1 of 19
Hi zofbtb,
Your speed is within the predicted range for your line so there's not really much that we can do as we can't raise this as a fault to Openreach for investigation.
Message 2 of 19
Stable (I've never has issues with VDSL cutting out with any ISP) but not as fast as it was.
Message 3 of 19
Hi zofbtb,
Apologies, I still can't see the profile. Just to confirm, how have you found the connection since your last post?
Message 4 of 19
Can you see my profile now?
Message 5 of 19
Hi zofbtb,
Still can't see the profile unfortunately, your current sync speed is 53.4Mbps
Message 6 of 19
Hi zofbtb
Yes line test is passing. I can't see what profile you're on at the moment, I'll check again later
zofbtb
Message 7 of 19
Still hasn't crept back up to what it was. Does the line look fine from your end? Any errors? What profile am I on? Thanks
Message 8 of 19
No issues per say but it (sync) should really get back up to the previous speed
Message 9 of 19
Hi zofbtb,
Thanks, the speeds look ok based upon the sync speed. Our Network Team have also advised that the speeds look ok. Just to confirm, are you experiencing any issues with the performance of the connection?
Message 10 of 19
fast.com 50/10
tt speed test 51/9.7
tt speed test (whilst logged in) 51.3/9.2
sync as shown in router 55.8/9.7
Message 11 of 19
Hi zofbtb
Our Network Team have asked if you can run a wired speed test using the TT speed tester so we can see the results?
Message 12 of 19
Hi zofbtb
I've escalated this fault over to our Network Team for investigation and I will post back on this thread as soon as I receive further information.
Message 13 of 19
yes, connected to test socket
Message 14 of 19
Hi zofbtb
Is the router connected at the test socket? Once I've confirmed this then I can raise this over to our Network Team for investigation.
Message 15 of 19
There's been no change
Message 16 of 19
Hi zofbtb
How has the connection been since your last post?
Message 17 of 19
Thanks. Rebooted yesterday afternoon - I'll see what happens over the next 48hrs (no change yet)
Message 18 of 19
I've updated the firmware for you now.
Turn the router off for 30 minutes to clear the current session, then turn back on and we can see if the DLM profile increases over the weekend.
