System reset due to kernel panic, Terminal:OTHER
ez9285
Message 3 of 3
Getting this error every day (router obviously crashing). Sometimes several times a day. Live support have been utterly unhelpful. Perhaps things will be better here?
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
Device Type:DG8041W
Description:EchoLife DG8041W Home Gateway
Hardware Version:I.1.01
Software Version:v1.05t
Message 1 of 3
Hi ez9285
Apologies for this.
I've made a change to the firmware on the router, please can you monitor the connection over the next few days and let us know how it compares?
Skynet_TX
Message 2 of 3
Hi @ez9285,
This is a known issue, the staff here on the community will be able to push out firmware version 1.06t to your router, and that should resolve the problem for you.
They will hopefully be able to respond to this post tomorrow to help.
