TP LINK try to get the paired for the same
19 REPLIES 19
hosay299
Hi i am trying to get some tp-link paired with the same as my wifi hub but seems not work is the hub light ment to chnage or flash when u press the wps bution
Hope that help Regards Joe
Divsec
Hi @hosay299 sorry you are having trouble, which model tp link are you working on? I never found wps a satisfactory solution.
hosay299
@Divsec hi I a issue set up the pair so the 2 units pair with my router.
https://www.tp-link.com/uk/home-networking/powerline/tl-wpa4220/
Any help would be good
I am trying to get them to work on mine so I know what to do when my friend has them
He's with plus net if that helps
I also have my own power line adaptors ones
Mine are unplugged when trying to get these plugged.
Mine are
TP-Link TL-PA4010PKIT Passthrough Powerline Adapter Starter Kit, No Configuration Required, UK Plug, Pack of 2
He want to use his as to extend his wifi.
So if I can cloine work then it simply to connect devices.
Seems info online good but not working.
That's why asking what router hub should do when press the wps button
Hope that gives you a clear understanding of the issue.
Divsec
Hi Joe, is the intention to try and use these devices entirely wirelessly which I'm not sure Is possible or more likely there are two powerline (pla) units involved.
The first unit needs to be connected to the router by ethernet then the second unit simply plugged into the electric socket try connecting a device by ethernet to check it is working OK.
Then press the wps button on your router, nothing visible happens, then the WiFi button on the extender for 1 second, once this stops flashing the connection is made.
If none of this works try this app https://play.google.com/store/apps/details?id=com.tplink.tpplc which is rather good.
All the best sorry if I've told you things you already know😊
D
hosay299
@Divsec  the kit has 3 units one small one to be plugged into the main by router and then sm2 wifi extender units I have tried what u said apart from app will try that way tomorrow Wednesday.
Thanks will see if tplink can help
Oce can I ask should the white light on hub flash when pressed the wps button???
hosay299
Mine are not compatible also looks like my friends are not a old version on show new version of it
OCE_Chris
Hi hosay299,
The light on my hub flashes orange when I press the WPS button, is that what yours is doing?
hosay299
@OCE_Chris  no even when turn off for 5 mins just to see will try for 30 mins later.
Do u think a reset of the hub is required???
Did think something was wrong with it when trying to pair the tp link kit.
@Divsec seems the router should be change colour.
@OCE_Chris i have just turned my router of for 30 mins then see if it does the light change after that if not may do a reset via the website page ???
just so u know
up date 5 30 pm just done power off with main unplugged for 30 mins no chnage
am going to try my old router a hg633
Chris why is the wps not working on hub
could it be a up-date issue????
hosay299
@OCE_Chris up date worked fine did the job on the other router have just do another reset on the hub and now seems to do the orange light flashing so will do a check tomorrow and see if it works like it should do
snice doing the reset i have not be able to login to the router page i have trieed what is on the back and the basic admin and admin but no joy.
can u check to see if everything is working fine can u access it
will try tomorrow to do the pair with the tp devices or might be thursday
thanks for u help so far
OCE_Karl
I cant seem to access the rotuer at the moment.  Can you try the 'pair' and see if it works.
hosay299
It is connected and I am to unable to login.
Will try the pair later today
@OCE_Karl do u thinks it's a router faulty??
As wps was not working before
OCE_Karl
It's difficult to say, only way to prove this is try another, do you want me to send one out.
hosay299
@OCE_Karl  yes if u can as 1st was wps not working now can't login to the website for access to settings.
OCE_Karl
Router on the way.
hosay299
@OCE_Karl hi have got the new router but just would like to know why no return bag for the old router ??
as another member has raised it in the iedas page @Weevie  see here karl
or do i now just put old one in the bin???
will swap over in a few mins the routers
also to add dhl i added on the tracker to leave in porch and the driver left it in front of proch on the milk create . Seems they do not follow the rule also was signed for by driver when tracker yersterday showened no signure required
OCE_Karl
I'll get a returns bag out to you now.
The couriers can be a bit hit and miss with delivery instructions.
hosay299
@OCE_Karl thanks
i have just connected the new one up
is the router up-date on it bites see below
TalkTalk Wi-Fi Hub
Version v1.05t
are u able to log in ???
i see it has changed a bite as the base is more softer on the surface and the plug is a different design.
i have turned the 5 wifi signal off as do not have any devices yet that will use it
love the new lay out on the setting page seems this are going up slowly in the right way
shame the pending order in my account does not show what it relates to as says fibre but must be the return bag
OCE_Karl
The router is up to date.  A new firmware is in the works and should be ready soon.
hosay299
Hi @OCE_Karl. Thanks for checking just got a different info from my old one.
Wps worked fine for pairing the tp kit.
How would we know of a update to firewire??
OCE_Karl
When the firmware is ready this will roll out in batches and routers will auto update.
