on 06-06-2021 03:41 PM
Following a fruitless conversation with TTB Tech Support, who hide behind the 'can't talk about non-TTB routers' wall, if anyone has any information about how to connect this router to TTB, I'd appreciate it. I do have the username/password/VLAN information and I gather that the DNS addresses are automatic. There is no sign of the router connecting and I do wonder if I do need more information. If anyone has any experience of configuring a third party router (preferably TP-Link) to TTB then I'd love to hear about it.
Thanks (hopefully!).
on 06-06-2021 08:47 PM
You could try a ZYXEL router/modem version XMG3927-B50A that will work on g.fast and normal FTTC connection
on 06-06-2021 05:07 PM
As others have pointed out this forum is for residential customers not business customers and TalkTalk's residential and business networks are different so what one applies to one may not apply to the other. If you do a forum Search for non-TalkTalk routers you should find the instructions for connecting to the residential network.
That said, there are some basic principles that should apply. The first of which is if the service you have is Fibre to the Cabinet then you will need to connect a modem to your incoming line and then connect your router to the modem using an ethernet cable. Secondly the modem connection should probably be MPoA rather than PPPoE.
The thing to remember is that the R605 is only a router and if you want to connect it to anything other than a WAN you will need a modem such as the Vigor 130 or equivalent, but make sure it supports the type of connection you have for example not all modems support g.fast.
on 06-06-2021 04:00 PM
Hi @Netadmin
I'm sorry but I can't advise you on connecting to TalkTalk Business line with a 3rd party router, only to the residential packages, as I am not a customer of TalkTalk Business, only TalkTalk residential.
on 06-06-2021 03:58 PM
If by TTB you mean a business line, then there is no forum support for business contracts.
From what I can see, the device you quote does not have an integrated modem so you will need a modem first.
How exactly are you trying to connect ?
on 06-06-2021 03:55 PM
And when you say TTB do you mean TalkTalk Business? In which case I am afraid these forums cannot really offer support.
on 06-06-2021 03:54 PM
Unfortunately this forum is for residential customers and all staff here (back on Monday) work for residential.
You may not find anyone here therefore, who can help you, but I have tagged someone who my be able to point you in the right direction( @KeithFrench any thoughts?).
Which type of fibre do you have, does it it come via a separate Openreach modem?
