Talk Talk Router, Eero 6 Pro and Orbi
ViperStripes
Message 6 of 6
I currently have the standard TalkTalk Router with Orbi Mesh system.
TalkTalk want to upgrade me to Eero 6 Pro but can't tell me if it replaces:
a) The router
b) The Orbi
c) Both
Also how much is a second Eero our house is 4 floors so we have 2 Orbi's.
5 REPLIES 5
jamsterdm
Message 1 of 6
4 months into my FF and would love eero
Message 2 of 6
Hey,
 @KeithFrench  is correct however im guessing this is for an upgrade to fibre to the home FTTP? as eero is only available on this product right now.  Assuming the above, then your router would essentially be replaced by an openreach modem which is essentially what we call the ONT the eero connects to the ONT and eero then becomes your Wifi router.
One point to make is that you get one eero device, you can purchase more but you should consider if you do have a number of orbi devices in your home will one eero be enough or would you need more? i dont know the answer to that but you should consider it as you wont be able to use both eero and orbit together.
Hope this helps.
Stephen, Community Manager
ViperStripes
Message 3 of 6
A nudge on this. Anyone have any idea? Surely someone at Talk Talk must know!
Message 4 of 6
From the way I understand it, it would replace both, but I have not seen one of these.
martswain
Message 5 of 6
@ViperStripes  wait for a reply here, please do not open multiple posts on the same subject.
