TalkTalk Hub Speed Dropping
DiddyP
Message 16 of 16
Hello, I've got a talk talk hub router and until recently it has been working without trouble. The last few weeks however - despite all the speed tests, cabinet tests, socket tests, the router keeps dropping download speeds from 25mpbs+ to 0.5mbps, about 4 or 5 times a day, every day.
I've tried resetting the router each time, and that resolves it for a few hours, then the speed drops again. Is it possible to order a replacement router please?
Diddy P
15 REPLIES 15
Message 1 of 16
I'm really glad to hear this and thanks for keeping us updated 🙂 I'm just sending you a short survey via a PM.
DiddyP
Message 2 of 16
Just a quick update a month later and indeed the new router solved the issue. Download and upload speeds are consistent and there is no drop out at all of connection. Seems that the router was the issue. Thanks for sending a relacement one.
Message 3 of 16
DiddyP
Message 4 of 16
HI Debbie,
Just letting you know that  we've receieved the new router. We'll test it out over the next few days and will get back to you here.
Thank you, DiddyP
Message 5 of 16
Hi DiddyP
Sorry for the delay.
DiddyP
Message 6 of 16
Hi Debbie, yes please - that would be great. I can confirm if it is the router for sure then 🙂
Message 7 of 16
Hi DiddyP
Apologies for this.
Would you like me to send a replacement router for testing?
DiddyP
Message 8 of 16
Hi Chris, Just letting you know that the factory reset did not resolve the issue. I still have to recycle the router to achieve gauranteed speeds. It seems like the speed degrades over the course of a few hours. A reset of the router resolves it initially.
Message 9 of 16
OK thanks, look forward to hearing how you get on
DiddyP
Message 10 of 16
Will do Chris. I'll see how it goes today and tomorrow and get back to you tomorrow evening.
Message 11 of 16
Yes, could you try it again and let us know how you get on
DiddyP
Message 12 of 16
A month or so Chris, yes I did, but it did not resolve the problem. Shall I try it again today
Message 13 of 16
Thanks for that. Could I just ask, have you tried resetting your router to factory default settings?
DiddyP
Message 14 of 16
Hi Chris, Thank you for the guidance, I've done just that.
Chris-TalkTalk
Message 15 of 16
Hi DiddyP,
If you still need assistance can you please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
