TalkTalk Hub fast 5364 slow sync speed compared to old
4 REPLIES 4
shu__
I recently received the Talktalk hub and ever since installing my Sync speed fluctuates between 30-60mb for download, I am on the fibre speed boost.
My previous router which was a rock solid in terms of sync speed, the TP link VR400 and would sync at 74mb.
I feel like the router is causing this issue?
My line stats are below, it seems upload has hit max speed.
                                    Downstream Upstream
Actual Rate [Kbps]         60000            19848
Maximum Rate [Kbps]    72696            19848
Noise Margin [dB]            9.60                6.10
Attenuation [dB]              18.20               0.00
Power [dBm]                    13.10             7.30
OCE_Debbie
Hi shu__
Your line is in sync at 57.4mb. I can see re connections on the line and this can affect the sync speed.
Is the connection dropping or have you rebooted the router?
shu__
Hi Debbie,
I rebooted the router as sometimes it syncs higher than it currently is.
OCE_Debbie
Hi shu__
Would it be possible to connect the router at the test socket for 48hrs (without rebooting the router)
We can then check to see if DLM increases the speed.
