Talktalk 150 ( G.Fast ) High upload latency
ciciox10
Message 24 of 24
Today I had my Talktalk 150 line install ( G.Fast )
the engineer took few hour to install it as he was detecting few issues on the line but after few test all get sorted ( from his tablet )
I been running a speedtest on speedtest.net ( CLI ) and at the same time a ping test but I notice that when the line is quiet ( pre-test ) ping is almost stable  ( before I had a normal DSL that was reaching 79.9 mbps and ping were always stable to 8 ms with plusnet )
C:\Users\giuseppe.faro>ping 8.8.8.8 -n 20
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=6ms TTL=117
Reply from 8.8.8.8: bytes=32 time=5ms TTL=117
Reply from 8.8.8.8: bytes=32 time=8ms TTL=117
when the speedtest is running ( download ) the latency is still fine
Reply from 8.8.8.8: bytes=32 time=7ms TTL=117
Reply from 8.8.8.8: bytes=32 time=9ms TTL=117
but soon is starting the test for the upload this happen
Reply from 8.8.8.8: bytes=32 time=87ms TTL=117
Reply from 8.8.8.8: bytes=32 time=123ms TTL=117
Reply from 8.8.8.8: bytes=32 time=112ms TTL=117
Reply from 8.8.8.8: bytes=32 time=122ms TTL=117
Reply from 8.8.8.8: bytes=32 time=130ms TTL=117
...... from here the upload is completed ...
Reply from 8.8.8.8: bytes=32 time=4ms TTL=117
I been running this test while the engineer was here and he said that the line look perfect from his tablet ( no errors ) but it will take up-to 10 days to get stabilized.
I am confident that in 10 days the line will stabilize but im not really sure that the latency in upload will change much.....
https://imgur.com/a/zDWnjz9 - Ping Test
https://imgur.com/a/EWCGiLd - Speed Test
23 REPLIES 23
Message 21 of 24
Hi ciciox10,
Thank you. I've run a test on the line which has detected a possible voice fault. Are you experiencing any issues with the voice service such as noise on the line or no dial tone?
Message 22 of 24
Hello Karl,
I just added my detail to the community profile
Thank you
Message 23 of 24
Can you please add your home phone number or Account number to your Community Profile so I can locate your details.
If unsure of your phone number, simply dial 17070 from your land line phone and this will confirm the number for you.
