Talktalk won’t connect to PS4
Naomi6
Message 15 of 15
Hello I recently bought a PS4 to connect to m wifi (I’ve been a customer for about 3 months I think) and the router name does not come up on the list, the console is fully updated, someone message back ASAP please kind regards
Nh
14 REPLIES 14
Message 1 of 15
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar as large images. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
Message 2 of 15
Hi @Naomi6
There is no other way that you can contact me direct, other than PMs. Please request that TalkTalk enabled them for you.
Message 3 of 15
Hello yes I’m dyslexic so I have trouble understanding things so am looking for simple answer
Nh
martswain
Message 4 of 15
@Naomi6  my post (#2) in this thread has the link with detailed instructions on how to split the SSIDs
Message 5 of 15
Heya is there another way I can find and contact you?
Nh
Message 6 of 15
It seems that you do not have PMs enabled as yet, please request in your reply that TalkTalk enable them for you. Once enabled (possibly Monday now), then I can PM you. I do not disclose my email address in this public forum, sorry.
Message 7 of 15
Please do do you already have my details?
Nh
Message 8 of 15
I will PM you some details.
Message 9 of 15
Hello yes do you have an email I can get back to you on ? To make it easier
Nh
Naomi6
Message 10 of 15
Heya sorry I can only put it on the top, I have a chromebook I can do the diagnostics with is there an email I can email you on which would be easier
Nh
Message 11 of 15
If you would like to answer my post I can guide you every step of the way, providing your console has a web browser? You will also probably need a smartphone or WiFi connected PC for some of the diagnostics.
Naomi6
Message 12 of 15
Heya how would I split those as I’m not a computer nerd lmao it’s really confusing is there a step by step I can do On the console
Nh
Message 13 of 15
Or there is WiFi interference.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using, there is a label on the rear of the router that will identify this? On the WiFi hubs, this is located behind the removable small plastic panel
martswain
Message 14 of 15
Does the router SSID come up on other WiFi devices in the same location as the PS4 ?
Suggest you split the WiFi SSIDs and see what happens.
https://community.talktalk.co.uk/t5/Articles/Split-your-router-s-SSID-wireless-network-name/ta-p/230...
Whilst logged in to the router dashboard check both the 2.4 and 5 GHz SSIDs are active.
Check both SSIDs are visible on another (dual band) device.
If your PS4 still cannot see the renamed SSIDs then it is either too far from the router or faulty.
