Terrible Speeds and Latency Everyday...
kaekae
Message 20 of 20
Been with talktalk for awhile now. but for the past 2 weeks my internets stability has been terrible..
My ping to a EU server constantly spikes to over 500ms for ages... my speeds drop, everything becomes unusable..
Trying to use LiveChat but currrently says its unavailable..
I also upgraded to Fibre65 from Fibre35 a few months back and my line is still being limited.
Actual Rate [Kbps]Maximum Rate [Kbps]
400005941
449885941
I was told by a representive my line can provide the full Fibre65 speeds...
Seriously fed up with it now.... and tired of constantly restarting my router attempting to fix it.
I will ring tomorrow unless something can be done sooner through here..
kae
19 REPLIES 19
Message 1 of 20
I've re-run the line test now which is still clear and the connection stats look ok. If it's possible to run another wired ping and trace route the next time this occurs then we can pass this over to our team to have a look.
Message 2 of 20
Hi Michelle,
Sorry for the slow response been extremely busy the past few days and also not been a home to run additional tests,
The issue is present at multiple times through the day however I noticed it more late at night and in the early hours.
I will try and provide more tests results in the future.
Thank you for the on going support.
Kae
Message 3 of 20
Ok thanks for confirming. I've just had another look at the pings and traces that you completed and the ping results look ok. Does it seem to happen at certain times of the day? Could you run a few more please when this next happens so we can see the results.
Message 4 of 20
Yes however they've never had any issues before and we've had no wiring changes that could be causing issues,
I have tested on a direct wired connection and the ping spikes are still present, aswell as on wireless.
Also I am not using the TalkTalk provided powerline adapters as ive had multiple sets of them and they always seemed to break within a couple months, I am using TP-Link AV600 (TL-PA4022P)
Below is a screenshot from my directly connected computer, within 0.5m of the router.
Message 5 of 20
Are you using any powerline adapters?
Message 6 of 20
No no these tests were only run when wired.
Message 7 of 20
Hi kaekae,
Thanks for the update. The results are showing high pings to the router. Just to confirm, did you run the tests when connected wireless?
Message 8 of 20
Hi Michelle,
Internets been a little bit better recently or I've just not caught it at bad times,
below is a screenshot of a ping and traceroute to google.co.uk aswell as a speedtest on SamKnows. both done within 5 minutes of each other however the ping and traceroute dont seem to show any issues. very low ping to google.co.uk as expecting yet at that time my VOIP client had extremely high latency aswell as the speedtest.
Many Thanks
kae.
Also a image showing I am on a wired connection and my last 30 days of usage ( this is 90%+ of my overall broadband usage so I highly doubt its other devices on my network. )
Message 9 of 20
Hi kaekae,
Ok thanks for confirming. Please can you run a wired ping and trace route the next time this happens and post the results into the thread please.
Run a Ping or Traceroute
Message 10 of 20
Hi Chris
No im not currently using the test socket. Also cant test for landline noise as we no longer own/have a phone connected.
Message 11 of 20
Hi kaekae,
Is your router currently connected to your Test Socket, if you have one?
Are you experiencing any problems with your telephone service, any noise on the line?
Message 12 of 20
All tests done on Ethernet, nothing downloading or uploading and I'm the only one currently home.
17:24:06test 1.png
22/07/2021
18:53:00
22/07/2021
19:28:00
22/07/2021
Message 13 of 20
Hi Karl,
Thanks for your response, as the issue is intermittent ill try my best to get you a screenshot of it in the next 12hrs including a timestamp.
Many thanks
Kae
Message 14 of 20
All tests are clear and no issues showing.
Your speed is at the highest your line can handle (40mb) and is performing as expected.
I've had a look at the DLM logs for the last 72hrs. There are some errored seconds showing however these are in low numbers, usually 2 or 3, nothing higher.
Can you try a wired test at https://speedtest.samknows.com and post a shot of the results.
kaekae
Message 15 of 20
v0lrWjy
Example of my terrible speeds recently. I was told to log in to the site https://www.talktalk.co.uk/speedcheck/
so that my recent tests can be seen however the login button is unresponsive for me.
Message 16 of 20
yes, the drop in speeds and latency peaking is on all devices, ethernet and wireless.
Plus should my sync speed not be higher as im on Fibre65? That has always been my sync speed even when on Fibre35(fibre medium or whatever it used to be called)
Issue has been ok recently and not had any bad peaks, im currently monitoring my ping 24/7 using an application to try and narrow down if it has a pattern or certain time of day.
Message 17 of 20
Hi kaekae,
Line  test is clear and router is in sync at 40.0Mbps. Are you experiencing the slow speeds and latency on both devices connected to your router by Ethernet cable and wifi?
kaekae
Message 18 of 20
Ah okay thank you for your response though, Im slowing getting onto livechat now just waiting for an available agent.
Skynet_TX
Message 19 of 20
Hi @kaekae,
Staff here won't be back until tomorrow now, but they should respond tomorrow to help further.
