UPLOAD Mbps
Faai_TT
Message 11 of 11
Good day.. I would like to know if it is possible to increase the upload speed? Is it possible to increase it? Thanks for the answer.
10 REPLIES 10
Message 1 of 11
According to this site, the only product that is symmetric is their UFO product sold in York and a few other areas, the other FTTP products (Data Only) via the Openreach network appears to be capped.
https://kenstechtips.com/index.php/talktalk-broadband-review
Message 2 of 11
A somewhat extreme suggestion @martswain, but I am sure we will all bear it in mind.  😃
Message 3 of 11
Move to Thailand !
When I get back there my FTTP connection is 500/500 for £14.75 a month.
They also have a crafty TOGGLE ability as per the picture below.
Message 4 of 11
Only with direct Fibre to the property. Hybrid products such as FTTC are by definition asymmetrical, with the emphasis on the downstream side.
Message 5 of 11
Is it possible to get a package where download and upload speed same?
Message 6 of 11
@martswain Great minds and teamwork, you beat me to it with the initial reply!  🙂
Message 7 of 11
@ferguson , you beat me to it again !
Message 8 of 11
Bearing in mind that the absolute maximum is 20Mbps sync if you happened to be right on top of the fibre cabinet with a concomitant drop off in throughput then it looks as good as you can get.
Message 9 of 11
martswain
Message 10 of 11
What product do you have ?
Please post your upload and download line rates along with the noise margins, you will find these by logging in to your router dashboard and then going to DSL information.
