Ultraslow Fibre 150
Jumble
Message 11 of 11
Fibre 150 installed a couple of days ago by Openreach engineer.
Fastest speed available since, has been 38Mbs. About the same as my previous package.
What am I paying the extra for or will it correct itself sometime.
10 REPLIES 10
Message 1 of 11
Hi @Jumble
The devices that are running OK may well be using the 5GHz band & the PC is on the 2.4GHz band as you say.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Message 2 of 11
Jumble
Message 3 of 11
I think the problem lies with my "older" PC. Tablet and phone are performing fine on wifi, achieving up to 140Mbs. PC still at 36Mbs.
Thanks to all for help.
Message 4 of 11
Can I just confirm, are the speeds ok if you connect wired? Is this only affecting the wireless speeds?
martswain
Message 5 of 11
What device is it and what WiFi adapter standard is it using ?
What WiFi link rate is it negotiating with the router ?
I have an older 2.4 Ghz device that will only connect at a maximum link rate of 54 Mbps and my latest smartphone only manages 135 Mbps no matter how close I get to my HUB, so they would be the limiting factors on a Fibre 150 service.
That's all before taking into account any local WiFi interference, cue @KeithFrench  !
Jumble
Message 6 of 11
2.4 Ghz
martswain
Message 7 of 11
@Jumble  what device are you using for the speed test and how is it connected to the router ?
If on WiFi, are you using the 2.4 or 5 GHz band ?
Simple questions.....
Jumble
Message 8 of 11
Running test while on wifi, am I being stupid or what ??
martswain
Message 9 of 11
@Jumble  what devices are you using, how are they connected and do they have WiFi or LAN adapters that can support speeds above 100 Mbps ?
Message 10 of 11
I'm showing the router is in sync at 160mb and all tests are clear.
Are you testing the speeds wired or over wifi ?
