on 26-04-2022 10:27 AM
I am connected to a Pulse Secure VPN system via my Windows 10 work PC. My VPN connecting keeps dropping often. I have a eero 6 system with extenders. I noticed my mobile drops connecting sometimes as well. It is quite annoying.
on 28-04-2022 11:07 AM
Hi Louiville
Thank you 🙂
on 28-04-2022 11:05 AM
Thank you will keep you updated.
on 28-04-2022 11:00 AM
Hi Louiville
on 28-04-2022 10:42 AM
Yes please.
Many thanks
on 28-04-2022 10:10 AM
Hi Louiville
Apologies for this.
I've checked and the firmware has been updated.
I have also completed a line test which hasn't detected any faults but I can see re connections on the line. Would you like me to send a different make and model of router for testing to see how the connection compares?
on 28-04-2022 09:14 AM
Still unstable at home, but constant connection at office and at other locations.
on 27-04-2022 06:55 AM
Hi Louiville
Can I just check, how has the connection been since your last post?
on 26-04-2022 04:16 PM
That seems to have made things worse as my WhatsApp calls started dropping, which has not happened for a long while. I will stick with latest update for now
on 26-04-2022 03:02 PM
OK, I've started the firmware update, it should complete in a few minutes
on 26-04-2022 02:59 PM
Yes that is fine
on 26-04-2022 02:58 PM
Is it OK to do it now, it will take a few minutes to complete?
on 26-04-2022 02:54 PM
Yes please
on 26-04-2022 02:37 PM
I could try changing the firmware version to see if other version works better with your VPN, would you like to give it a try?
on 26-04-2022 02:25 PM
IT department had mentioned that the previous VPN had issues with TalkTalk, but this should be fine. It seems to be more stable in the afternoons.
on 26-04-2022 02:24 PM
It was installed in March 2022.
on 26-04-2022 02:19 PM
Did you have the VPN installed recently?
on 26-04-2022 02:02 PM
I have had this problem since the VPN installed and general performance issues with video calls since I have had TalkTalk.
on 26-04-2022 01:55 PM
Is this a problem that's started recently or have you always experienced problems with the VPN?
on 26-04-2022 01:36 PM
I lose access to my work files temporarily. The VPN connection tries to reconnect then it works. I don't have this issue at the office or at my mum's sky broadband.
on 26-04-2022 01:18 PM
Thanks. What actually happens when the VPN drops, do you get an error message?
