Updating talktalk hub
clong
Message 8 of 8
Is there a way to force the firmware update of the hub? Phone support suggested there was a button in the web UI but it requires a file to upload....
Current version is SG4K10001400t and my through put seems to be ~80Mbits rather than the 500+ i should get. (I get alot more with a 3rd party router)
7 REPLIES 7
Message 1 of 8
Hi clong,
I'd give them another try as the router needs to be updated remotely
Message 2 of 8
Thanks Michelle, this is the team I started with who said to look for an update option in the router UI - but it needs a file uploaded locally.
Message 3 of 8
Thanks for confirming. I'd recommend contacting our Future Fibre Team below via Live Chat.
Your Future Fibre Support Hub
Message 4 of 8
Hi Debbie,
I have no landline number any more as this is the data-only future fibre connection....
Message 5 of 8
Hi clong
I can check this for you. Have you added the correct landline number to your Community Profile? (please do not post the number on this thread)
paulshent
Message 6 of 8
As an extra comment.  If this is a newish change, Then first power off router for a full 35 mins. Then power back on.  This will create a new network profile for your service.  Latest firmware at moment is 2816t, but you will get same response from network following my suggestion.
Skynet_TX
Message 7 of 8
Hi @clong,
There is no way you can update the firmware yourself, if this is a new router the firmware will probably update automatically overnight within a few nights of the router being connected. Alternatively the staff here on the community will be able to push out a firmware update manually if your router is not updating automatically. They will hopefully be able to respond to this post tomorrow to help.
