Upgrade to Fibre 65 - no increase!
Golfermad
Message 10 of 10
Upgraded to fibre 65 speed has stayed at 30mbps
9 REPLIES 9
Message 1 of 10
Hi Golfermad
I've checked the connection stats and your line is in sync at 30.9mb.
I'm just sending you a Private Message to confirm some details so we can check the predicted speed range for your line.
Message 2 of 10
The staff here should be able to pick this up over the next day or two to investigate, if your line is really not capable of speeds well over 40mbps then there is no point being on Fibre 65, but the staff here will be able to check and confirm, the loyalty team should be able to move you back to Fibre 35 if necessary.
Message 3 of 10
estimated speed is 16-35.Plan shows Fibre 65 and I was allowed to upgrade - I would not have increased my payment and extended my contract if I thought I was going to have no differrence.
Message 4 of 10
@Golfermad,
If your estimated speeds are under 40 then that may well imply the upgrade has not happened, if you log into 'My Account' does it show that you are now on Fibre 65 ?
I am of course assuming that when you upgraded TalkTalk told you that you would get speeds well in excess of 40mbps, they should not have invited you to upgrade to Fibre 65 unless your line was capable of speeds well over 40mbps.
Staff will respond soon to help further.
Message 5 of 10
Thanks 👍
Message 6 of 10
Staff will only reply to the original poster on the help boards, @mattvent. This is to avoid delays in reaching the customer and to avoid confusion.
So, yes, you must return to the message board and click on start a topic.
It could be a couple of days before you get a response from staff.  They work from oldest to newest posts and are still catching up on the backlog from the weekend.
Message 7 of 10
I'm having the same issue - should I start a new thread or contribute here?
Message 8 of 10
Estimated speed shows 15-35mbps. Actual speed is 30 mbps
Skynet_TX
Message 9 of 10
Hi @Golfermad,
If you go to the Service Centre what does it show for your 'estimated speeds' and your 'measured speed'.
If your 'measured speed' has increased to the faster Fibre 65 speeds that you expect then it would be worth switching the router off for over 30 minutes, then when you switch it back on it will start a new 'session' in the street cabinet, this can sometimes help it reconnect at a better speed.
Then they will hopefully be able to respond to this post within a working day or two.
