on 20-01-2022 09:23 AM
My existing Fibre 35 contract runs out in a couple of days and I was going to upgrade to Fibre 65. On the page confirming the upgrade it says I'll be charged £9.95 for the post and packing of of a Wi Fi Hub black, I already use this router with my fibre 35. Has this router changed or am I being charged and sent a new router for no reason.
on 20-01-2022 03:48 PM
Thanks for your help. They have to send out a new router as part of the order (sounds a bit wasteful), but they've credited me with the cost of the post and packaging.
on 20-01-2022 10:47 AM
It is not needed, it is exactly the same as your current router. Try contacting the Loyalty Dept (0345 1725157) & say that you do not need it.
