on 21-01-2022 06:58 PM
I need advice as I've been given conflicting advice.
I have an engineering coming to upgrade us from Fibre 60 to 150 next week, 25 Jan. I was told by the sales assistant that I could continue using my own router equipment, I don't use the talk talk WiFi hub (the provided one was lost). However, I've recieved a letter along with a cat5 cable this morning saying I must have talktalk WiFi hub before an upgrade can take place.
Does anyone use Fibre 150 with a custom router? Or been through this upgrade procedure. Did the engineer bring any additional equipment to attach to the router?
on 26-01-2022 07:39 AM
Thanks for confirming 🙂
on 25-01-2022 07:05 PM
It's working well. Thanks for checking in.
Took a bit of configuring but I was able to get it working with my existing equipment.
on 25-01-2022 01:34 PM
How are you getting on?
on 21-01-2022 08:23 PM
I've not been told, but would assume it's FTTC. Great, sounds like I can continue to use my existing equipment and attach the new modem. Thanks @ferguson
on 21-01-2022 08:15 PM
OK, I am assuming you are upgrading to a faster FTTC service, rather than full fibre. In which case unless the inbuilt modem is G.Fast compatible you will need to connect your device to the modem supplied by the engineer.
on 21-01-2022 08:12 PM
Thanks for the advice @ferguson.
I'm upgrading from Fibre 60 to Fibre 150. I currently use an open source openwrt based router that has an integrated phone line based modem in it. This connects direct to the phone line through which the broadband is provided. I use a separate mesh WiFi system to cover my flat with WiFi. This connected directly to the openwrt router via a cat5 cable.
on 21-01-2022 07:19 PM
I should have added that there will be extra equipment installed, either a G.Fast modem, or an ONT, depending on which service you are getting. Which again you neglected to tell us.
on 21-01-2022 07:14 PM
You will probably be OK, although you haven't given any details of your own router and subject to what the engineer says. Bear in mind that TalkTalk cannot be held responsible for any connection issues unless you are using the equipment supplied by them.
