Upload Speed on Fibre slow
Andrew5617
Message 30 of 30
Hi, I was wondering is it possible to increase the upload speed on Fibre broadand. I am getting a good download speed of 37Mbps but only getting 5Mbps upload. This is causing issues with voip calls when both myself and daughter are working from home. I have turned off the router for 30mins as advised in other posts but the upload speed does not improve.
Many thanks
Andrew
29 REPLIES 29
Message 1 of 30
Hi Andrew, please let us know how you get on
Message 2 of 30
Hi Michelle
Thank you for your response and assistance in looking into my issue. I will see how things go and if things do not improve, I may have to look into what alternatives are available.
Thanks again for all your help it is greatly appreciated.
Andrew
Message 3 of 30
Hi Andrew,
Apologies, we can't manually adjust profiles for fibre as this is managed by DLM to provide the best balance between stability and speed for the line.
Message 4 of 30
Hi Chris
Thank you for your reply. I was hoping there was a way to adjust the upload speed similar to the adjustment that used to be made to ones profile e.g. to 6db to increase the sync speed.
Andrew
Message 5 of 30
Hi Andrew,
Thanks for the information. I'm not sure what else we can do, BT don't guarantee upstream speeds but having said that your upstream speeds are within the predicted range for your line.
Message 6 of 30
Hi Michelle
I have not found any great imporvement in performance all about the same as before.
Andrew
Message 7 of 30
Hi Andrew,
Thanks for the update. Apologies I can't see your connection stats at the moment. How have you found the overall performance of the connection since the router has been connected at the test socket?
Message 8 of 30
Hi Michelle
Please see below the speed tests I performed over the weekend.
Andrew
Speed Tests
Sat 29/08 9:40am
36.6 Mbps Your average download speed
6.1 Mbps Your average upload speed
Sat 29/08 16:30
35.4 Mbps Your average download speed
6.4 Mbps Your average upload speed
Mon 31/08 14:30
34.2 Mbps Your average download speed
6.3 Mbps Your average upload speed
Mon 31/08 16:30
6.2 Mbps Your average upload speed
Message 9 of 30
Hi Andrew,
Great thank you 🙂
Message 10 of 30
Hi Michelle
Okay thanks. I will test again at the weekend.
Andrew
Message 11 of 30
Hi Andrew,
Thanks for the update. It's possible that DLM may continue to increase the upload speed over the next 48hrs now that the router is connected at the test socket.
Message 12 of 30
Hi Debbie
I have connected the new router to the test socket. Please see below my speed test. There is a little improvement on the upload but not as much as I would like.
Andrew
We've finished measuring your speed, and here are your results.
35.5 Mbps
6.4 Mbps
Message 13 of 30
Message 14 of 30
Hi Michelle
Will do
Andrew
Message 15 of 30
Hi Andrew
Message 16 of 30
Hi Michelle
Yes Please that would be great.
Andrew
Message 17 of 30
Hi Andrew,
Sorry for the delay. Would you like us to send a different router for testing purposes?
Message 18 of 30
Hi Michelle
No I do not have another router I can use to test, only upgraded to fibre in January, unless the old fast broadband router will work.
Andrew
Message 19 of 30
Hi Andrew,
Thanks for trying this and I'm sorry that there hasn't been any improvement in speed. Do you have an alternative router that you can test with at all?
Message 20 of 30
Hi Michelle
I ran another speed test this morning. Please see the results below.
Andrew
34.5 Mbps
5.3 Mbps
