on 28-04-2019 05:38 PM
My upload speed seems to have gotten a lot slower , was almost 19 Mbps now it is down almost to 2Mbps . My router shows the Upstream line rate as 20000 and a max of 23158 .Can this be reset ? Or fixed somehow . Thanks .
on 01-05-2019 07:47 AM
Hi kuroneko,
Ok thanks for confirming this 🙂
on 30-04-2019 09:49 PM
The router is the Talktalk Huawei HG633 .
Upload speed seems to be staying at about 18Mbps , so seems to be OK at the moment .
on 30-04-2019 08:24 AM
Hi kuroneko,
Thanks for the update. I've run a test on the line which hasn't detected a fault. Which router are you using? (make and model)
on 29-04-2019 09:49 PM
OK tried turning off the router , left it off about 40 mins made no difference . But my upload speed seems too be going back up , started to last night , each time I run a test it's a little faster , back up 10 Mbps at the moment so hopefully it keeps going up .
Not sure if it's related but my router has started to loose the connection between my devices ( Hi Fi , iPad , phone , ect ) They all remain able to connect to the internet but wont connect to each other until I either reboot the router or go into the routers settings and turn off and back on the Wi-Fi , then every thing is fine for a few days until it happens again . Just started doing this a few weeks back never lost any connections before then .
on 29-04-2019 10:02 AM
Hi kuroneko,
We'll then look into this further. Please do not post this information on this thread Once you've updated your profile please post in your topic to confirm it's updated.
on 29-04-2019 09:25 AM
Hi Kuroneko, welcome to the community your post has been flagged for assistance and you should hear during the day. In the meantime please check your community profile and add your landline phone number if necessary it is used to identify your account.
Have you tried rebooting your router? Switch of leave it for 5 minutes then back on? Only do this once or twice a day at most.
Do you have any noise on your phone line?
