Using a Tp-link TD-W8961N router with Fibre 35 - settings needed?
stephenco
Message 5 of 5
I'm trying to connect the TP-Link router but it's not allowing me to connect. The only thing I've added is my phone number xxxxxxxxxxx@talktalk.net as the username.
Could someone please advise me if there are other settings.
4 REPLIES 4
Message 1 of 5
Thanks Birchcroft, the paragraph I'd referred to indeed stated TD-W9970 supports VDSL. I should have noticed that. I'll return it to Amazon and perhaps purchase a TD-W9970 as it should work.
Message 2 of 5
Hi @stephenco agreed it does say the TD-W9970 supports VDSL which it does and it should work with Fibre 35.  However you stated that you are trying to setup the TD-W8961N which is ADSL with no support for VDSL and therefore will not work with Fibre 35.
If you actually have the TD-W9970 then you should set it to VDSL and follow TalkTalk's guide to setting up non-TalkTalk routers.
Message 3 of 5
I took a quick look at https://service-provider.tp-link.com/vdsl/td-w8961n/ and it seems to suggest in the 4th paragraph that 'Compatible with Fiber/Cable service' and that 'The TD-W9970 supports VDSL/ADSL'. I'm a little confused.
Birchcroft
Message 4 of 5
Hi @stephenco a guide to setting up 3rd party routers can be found here.
However a quick look on the internet would seem to indicate that the TD-W8961N is an ADSL router and does not support VDSL.  If that is the case then it won't work with Fibre 35.
