VPN Blocked
jon_t
Message 9 of 9
Since Wednesday my VPN access no longer works. Reading on here this appears to be an issue with a firmware update on Tuesday 11/01/2022? The version shown on my router is  SG4K100130. I use the VPN whilst working from home. I have tested the VPN access on other networks and works fine. Just not on Talktalk. Any assistance would be gratefully received.
8 REPLIES 8
Message 1 of 9
I'm sorry to hear this. Please can you create your own topic and we can look into this further for you.
leahcapewell123
Message 2 of 9
Hi Debbie, sorry to hijack the post but im having the same issues can i request a Huawei Hub please
Message 3 of 9
I'm updating your firmware now, it should complete in a few minutes
jon_t
Message 4 of 9
Yes please. As a speedier route to fix the issue. The router is on. Please let me know if you need anything from me.
Message 5 of 9
I can try a different firmware version to try to resolve the issue, would you like to give this a try?
jon_t
Message 6 of 9
Yes. Please send me a new router ASAP. I’m due to change to FTTP with an Amazon eero 6 pro on Friday. I’ve not received the Amazon router as yet. Will my current broadband type work with the Eero router if this is sent Sooner? Regards Jon.
Message 7 of 9
Hi jon_t
I can send you a different make and model of router. Would you like me to arrange this?
Message 8 of 9
Yes, this is known about & is under investigation.
