on 19-01-2022 08:16 PM
After a year of not having a problem my work VPN won't connect today, I've reset the router, I can connect when tethered via a phone but not over wifi or ethernet cable on the talk talk modem. Please advise a solution.
C
on 20-01-2022 08:44 AM
Hi C1234
No problem 🙂
on 20-01-2022 08:40 AM
Great, thanks : )
on 20-01-2022 07:53 AM
Hi C1234
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
on 20-01-2022 07:38 AM
Yes please, anything to get me connected again : )
on 20-01-2022 07:35 AM
Hi C1234
Would you like me to send a Huawei WIFI hub for testing?
on 20-01-2022 07:26 AM
Yes, both that and via the router settings page. Neither makes any difference.
on 20-01-2022 06:52 AM
Hi C1234
Your router firmware version is - 2816t.
Can I just check, did you factory reset the router using the pin hole reset for ten seconds?
on 19-01-2022 09:05 PM
Ok, you do have the Sagemcom router, but that is not the latest version of firmware (it is firmware SG4K100130 that has only just been released that has recently caused a few issues with VPN connectivity).
The staff here on the community should hopefully be able to respond tomorrow to help with this.
on 19-01-2022 08:50 PM
I don't know, the version says SG4K10002816t.
And yes windows built in VPN.
on 19-01-2022 08:42 PM
Hi @C1234,
Do you have the Sagemcom Wi-Fi Hub ?
If so, if you go to http://192.168.1.1/ and look at the 'version' towards the bottom of the screen is it SG4K100130 ?
What VPN software are you trying to use, is it the built in Windows 10/11 VPN ?
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
