VPN slows down connection
paddyward
Message 12 of 12
When I am connected to my VPN my speed drops down to about 15 mbps, instead of the normal 50 mbps without the VPN.
The speed drop is not due to the connection, as I have tried it on my phone through 4G and the speeds are almost the same as not being connected to it. Also I did not have this probelm when I was with PlusNet.
I have tested the connection multiple times on different days, so it is not just a fluke.
Is TalkTalk slowing down VPN connections? I have seen many other posts about this problem.
11 REPLIES 11
Message 1 of 12
Hi JWilliams4,
I'm sorry to hear this. Please can you create your own thread and we can look into this further for you.
Message 2 of 12
@Karl-TalkTalkHi Karl. I’m getting an almost identical problem as the other guy in this thread earlier. Is there any fix and do we know if the new router sorted the problem @paddyward If so how do I go about getting one?
Message 3 of 12
A new router is already ordered 🙂
Karl,
Message 4 of 12
Sorry, just re-read your message.
Unfortunately we don't have our old router that worked anymore because when the technician came around he took it with him, and left us with the d-link.
Is there anyway you guys could send the other router to test if it is a problem with the d-link router?
Message 5 of 12
No Problem 🙂
Message 6 of 12
Great, thanks
Message 7 of 12
I'll swap out the router and see if this works better with your vpn.
Message 8 of 12
On the back it says D-Link DSL-3782.
Message 9 of 12
What model router are you using.  The router itself should not slow the connection.
Message 10 of 12
Thanks for the response Karl.
So is there nothing that can be done? I can no longer use my VPN with my talktalk connection? I don't think this problem occured when we had our old talktalk router, strange that it has started up since getting the new router.
Message 11 of 12
VPN connections are not throttled or slowed down.
you have to remember that a VPN connection is a tunnel connection to a server so the speeds are dependant on the incoming and outgoing speeds of that server and cannot be guaranteed.
