VPN suddenly not working using Sagecom FAST5364-3.T8 Router using firmware version SG4K100130
herbm
Message 4 of 4
My VPN has stopped working today using the router and firmware mentioned in the title.
I am still able to connect to the VPN through my mobile network using a personal hotspot.
I have also connected an old Sagecom FAST5364-3.T8 router which is currently running firmware version SG4K10002816t and the VPN is working fine.
I have noticed that a number of other customers have had similar issues with SG4K100130 and I am concerned that the old router will eventually update to the latest firmware and I will have the same issue connecting to my VPN.
Do I need a different router? If so, could you please send one out.
3 REPLIES 3
Message 1 of 4
You're Welcome 🙂
Message 2 of 4
Great, thanks.
Message 3 of 4
I'll swap out the router for a different model and see if this helps.
