WAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
Sigals1
Message 9 of 9
I keep getting these messages in my logs multiple times per day and my download speed reduces dramatically until I restart the VDSL connection. Can someone look into this.
01:57:29 25/01/2019SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 connected.
01:57:28 25/01/2019SystemNoticeDSL connection is active.
01:57:01 25/01/2019SystemNoticeWAN connection INTERNET_B_VID_101:IPv4 disconnected.(ERROR_NO_CARRIER)
01:57:01 25/01/2019SystemNoticeDSL connection is inactive.
8 REPLIES 8
Message 1 of 9
Hi Sigals1,
Ok thanks for the update and please let us know how the connection compares.
Message 2 of 9
Thanks Debbie, I have received it and configured it - I will monitor it over the next few days and get back to you. I used the new included micro-filter and RJ-11 cable connected to the BT Master Socket. Cheers.
Message 3 of 9
Hi Sigals1
I've ordered a replacement router for testing, please allow 24-48hrs for this to arrive.
Message 4 of 9
Hi Michelle, I do not have another router to test with. Thanks.
Message 5 of 9
Hi Sigals1,
Thanks for confirming this. Do you have an alternative router that you can test with? If not then let us know and we can arrange to send a replacement router for testing purposes.
Message 6 of 9
Thanks for the quick response Michelle, very much appreciated. This has been going on for some months now.
See below details of the modem:
Product type: HG633
Device ID: 00E0FC-C4R8W16A17000483
Hardware version: H.1.01
Software version: v2.00t
I've also attached a summary of my speedtest results over the past few months when this issue occurs you can see a clear dramatic drop in down speed until I restart the VDSL connection - strangely upload speed is never affected.
I also have the modem plugged into the BT Master Socket.
FbvanyK
Message 7 of 9
Hi Sigals1,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault. Which router are you using? (make and model)
Message 8 of 9
