WHy speed test says the same after each test
hosay299
Message 26 of 26
WHy speed test says the same after each test why is this no change or made better info of it as in doing something????
as it seems not to do the old normal checks like when on normal speed test.
Speed test messageSpeed test message
Hope that help Regards Joe
25 REPLIES 25
Message 1 of 26
Ah, i didn't realise that you could .
Message 2 of 26
@skygrowler wrote:
yes i was logged in to my account .can you do a test not logged in ?
Yes, absolutely!  ~R.
Message 3 of 26
@Michelle-TalkTalk
ok thanks
@ferguson Well they might do somthing for us who do not know why they have done somthing already....been like it for ages
Message 4 of 26
Hi hosay299,
I've passed your feedback on the relevant team and they will look into this in regards to future improvements to the speed tester.
Message 5 of 26
Hi hosay299,
I'm currently looking into this and I'll let you know as soon as I know more.
Message 6 of 26
@Michelle-TalkTalk
Yes i am i all ways do it that way???
in windows 10 pc in google chrome???
Message 7 of 26
Hi hosay299,
Are you running the speed tester when logged into My Account?
Message 8 of 26
@TheHornedOne wrote:
Indeed 😰 ....... but were you loged-in to My Account when you ran that particular test?
~R.
Message 9 of 26
Hmm i see what you mean @TheHornedOne the throughput speed is shown in the hub settings as 80 mbps althouh the hub graphic only shows 3 reference points so not really like for like .
Message 10 of 26
~R.
Message 11 of 26
ah yes i have unfortunately "gone fibre " i assumed from the OPs speed so had he ? i think it just goes to show that as i have found speed isn't everything !
Message 12 of 26
You will also notice @skygrowler, that unlike my throughput data, you, and hosay299, have no figure logged against the router .....
Screen Shot 2019-01-08 at 07.01.39.pngScreen Shot 2019-01-08 at 07.01.39.png
......... but then, you've 'gone fibre', haven't you; an anomaly which I drew attention to in a previous post, and, were you logged-in to My Account when you ran the test, I was.
Are these salient factors?
~R.
Message 13 of 26
mine also says "not returning enough data " Screenshot 2019-01-07 at 16.43.28.png
Message 14 of 26
@ferguson wrote:
OK, are any of those recent?
As requested .........
Message 15 of 26
I totally agree with you @hosay299. I would expect "everything is fine," or "there is a problem." But "not enough data" what on earth does that even mean, something wrong with the checker?
Message 16 of 26
@Michelle-TalkTalk Just bite odd as when i was on normal broadband it would say somthing like ur speed is good type thing or ur speed is slow message.
just would think it would be a bite better if it ment somthing or said somthing better as mine shows the  bite under the the spee to your device
why can not not say somthing different as why say what it does all the time???
Message 17 of 26
Hi hosay299,
The message is dependent upon the test results. Apologies if I've misunderstood what you meant. Are you experiencing any issues with your connection at the moment?
Message 18 of 26
Topic locked pending OCE reply, to prevent further trolling.
Message 19 of 26
Message 20 of 26
 .... just a couple of examples:
