WIFI connection keeps switching channels
tinkersim1863
Message 7 of 7
I have a sagemcom router which keeps changing my WIFI channels. Can this channel optimisation be turned off please.  Every time it changes the channel my connection drops. Firmware version is SG4K10002816t
6 REPLIES 6
Message 1 of 7
Hi tinkersim,
I'm glad to hear this and thanks for the update 🙂
Message 2 of 7
Hi Debbie
Thanks for the help the issue is now resolved and the connection has stabilized.
Message 3 of 7
Hi tinkersim1863
Apologies for the delay.
This has now been switched off, please let us know how the connection compares following this.
Message 4 of 7
Yep, much better to deal with a request like this on this community, the staff here are used to getting this request and so will understand what you are asking for 🙂
Message 5 of 7
Thanks for the information updated profile, rang them and they didnt understand trying a different method.
Skynet_TX
Message 6 of 7
Hi @tinkersim1863 ,
The staff here should be able to disable this behaviour for you.
For one of the TalkTalk staff on this forum to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
