WIFI dropping out
trevor17
Message 3 of 3
I am having issues with the WIFI dropping out on connected mobile devices. The broadband to the router is not the issue, as computer connected by LAN and no issues with this device.
Had the router for a few years, and in the past i have no issues with mobile devices, but last month, having issues with them connecting.
Has anyone any ideas?
Trevor
Message 1 of 3
Hi Trevor
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
