WIFI modem
imlah
Message 22 of 22
Quick question, Do you get the free upgraded WIFI modem when you upgrade to superfast fibre ?
Talk talk want to charge me for a new modem, as im using a non TalkTalk one at moment, and having speed issues.
Is it possible to reset my profile at the exchange ?
Andy
21 REPLIES 21
Message 1 of 22
Hi Andy,
Thanks for the update and please let us know if you need any assistance 🙂
Message 2 of 22
Engineer arrived yesterday.
He found a fault with the splitter in the fibre cabinet.
This was replaced and my profile reset.
I have also received my new Wifi-Hub. setup and working well.
Hopefully that's all my problems fixed
regards
Andy
Message 3 of 22
Hi imlah,
I can see that the engineer appointment has now been booked, please let us know how you get on
Message 4 of 22
Yes been having trouble all week.
Need to arrange openreach engineers again.
Would it it be possible to arrange an appointment for Tuesday at 1pm to 6pm.
Message 5 of 22
Hi imlah
Have you arranged another engineer visit?
Message 6 of 22
The engineer was around and had problems pinpointing the issue, changed master socket as thought it might be that.
Again today we are having problems maintaining a connection?
will be in touch to arrange another visit.
Message 7 of 22
Hi imlah,
Thanks for the update and please let us know how you get on. The engineer will run full tests on the line to identify any issues.
Message 8 of 22
OPENREACH coming tomorrow at 13:00.
I have arranged time off work.
Talktalk router arrived this afternoon.
Are the openreach engineers aware of the copper fault you discovered while testing?
Hope to have a update soon.
Will keep you informed
Andy
Message 9 of 22
Hi Andy,
Is there another day when you can be available for the full time slot
imlah
Message 10 of 22
Can manage about 13:15 to 18:00 on a friday
Message 11 of 22
Is there any other day that someone can be available 8-1 or 1-6pm ?
imlah
Message 12 of 22
Sorry no one at home until 14:15
Message 13 of 22
An update - Openreach appointment has been confirmed for Wed 8th AM (8-1).
Is this day / time ok.
Message 14 of 22
I've raised this to Openreach requesting a non appointed visit.
Message 15 of 22
Tests all done, you can pop all equipment back on.
Line tests are no longer showing a loop fault, so that rules out an equipment fault, but Fibre tests are picking up a copper joint fault on the line so this does need to be raised for an Openreach engineer.
I'll drop you a PM with the info required.
imlah
Message 16 of 22
That’s is done.
Only phone one connected to master socket.
No router connected
Message 17 of 22
Please.  Let  me know as soon as this is in and I'll start the test and post back.
imlah
Message 18 of 22
What equipment do I connect to the test socket?
Just the phone?
Message 19 of 22
As you are on fibre, we have n access to reset DLM at the exchange as this is automatically controlled by the BT systems.
I am picking up a loop fault on the voice tests.  Do you have a test socket ?
If you do, can you connect the equipment into the test socket directly and I can then retest to see if the loop is still present.
imlah
Message 20 of 22
I’m getting about 50 to 55 mb download.
No no noise or cracks on landline
new master socket and wiring fitted last last week as having lots of drop outs and disconnecting etc.
Are you you able to reset the exchange to optimise my new master socket and wiring
many thanks
andy
