Weak wifi
Jo-37
Message 7 of 7
My WiFi has been so weak lately and getting worse. Only a couple of devices can be connected at a time. I have 4 children needing to do in-line learning and have already used do much data as having to hot spot all the time. How can I boast the WiFi or do I need a new router? Broadband seems fine, speed good and wired connection to tv working great. But WiFi is shockingly awful!
6 REPLIES 6
Message 1 of 7
Not neccesarily. If the problem is caused by WiFi interference, then no new router can help.
Message 2 of 7
Thanks Keith. I will give what you said a go, but will have to wait till later as busy now. I’ll let you know how I get on.
Also as router is quite old would getting a newer one be a good idea?
Message 3 of 7
Hi @Jo-37
As @ferguson said, I can offer a lot of help with this sort of issue.
The HG633 is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the unique router password (see the label on the rear of the router at the top).
Go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
Having said that, there is another approach which can be better, which is to use Band Steering. This will automatically move any 5G compatible device connected to the 2.4G band to the 5GHz band. This is available on the HG633 (V2.00), to enable it, first set both SSIDs to the exact same name. Then go to:-
Home Network > Wireless Settings > Enable Wireless Network Frequency Bands
Then put a tick against Enable Band steering.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Message 4 of 7
OK, to be fair that is quite an old model. Let's see what Keith has to say.
Message 5 of 7
It’s a Huawei-HG633 apparently.
Message 6 of 7
Which make/model of router do you have?
We are lucky to have a resident expert in such matters: @KeithFrench can you help, please?
