Well Below Guaranteed Speed
Rich1971
Message 11 of 11
Hello
I am getting very slow speeds this morning. Nothing in my set up has changed.
The router says its connected at 53.9 down/13.6 up.
My speed test with Ookla is 2.38 down/12.79 up. Running a speed test on the service status page give a result higher(hmmm) but only 4 down/13 up.
I have tried all the usual, restarting the router, only one device connected by ethernet, remade all connections etc
The "live" connection test is pointless. It's obviously not live otherwise it wouldn't say if its a recent issue then it might not have detected it so try in 15 minutes! I've been on this for over an hour now so...
Can someone please try and resolve this.
Many thanks
Rich
10 REPLIES 10
Rich1971
Message 1 of 11
Thanks! I'll give it go.
Message 2 of 11
It most certainly will, I personally find the Huawei to work better than the Sagemcom.  🙂
Message 3 of 11
Router received, thanks for getting on this so quickly.
One question though. My current router is a sagecom model whereas the new one is a Huawei model.
I've read that the Huawei model is for 38mb fibre and the sagecom for 67mb.
I'm currently on 67mb, will this replacement router work at this speed?
Message 4 of 11
Router is on the way.
Message 5 of 11
I guess another router is worth a try, thanks.
Message 6 of 11
Ok, do you want to try a replacement router to rule out a hardware issue before we request an engineer ?
Message 7 of 11
Thanks Karl.
The line has always been a bit noisy but nothing out of the ordinary today.
Message 8 of 11
Hi Rich1971
Line tests are passing but I can see the recent speed tests are low. I am detecting an increased voltage across the line.
Can you check the home phone, is there a clear dial tone or any noise on the line.
Rich1971
Message 9 of 11
Hi Divsec
Thanks for that.
Hugely skeptical of the 30 minute power off but tried it anyway. No change.
Also tried a factory reset of the router and still no change.
Divsec
Message 10 of 11
Hi @Rich1971  have you tried a 30 minute router reboot this often improves things?
Your post has been flagged for assistance and you should hear soon but please remember that the staff here work office hours.
