on 21-01-2022 08:27 PM
Been on Fibre 35 for a number of years with 40mpbs router connection and 37mbps throughput when measured on a PC connected via ethernet.
Just renewed on Fibre65 and router has increased connection to 50.3mpbs but the throughput is the same at 37mpbs.
It's within the guaranteed speed of the line, but can anyone explain why the speedtest on the PC hasn't increased with the higher 50mpbs connection?
Similar results on 5G WiFi.
Answered! Go to Solution.
on 24-01-2022 07:28 AM
Thanks for the update and please let us know if you need any assistance 🙂
on 22-01-2022 05:55 AM
@Tim5230 , the good old turn it off and on again seems to work once again.
Apparently the key to this and other stuck speed scenarios is "more than 30 minutes" as that clears any memory effect in the associated equipment and software.
on 21-01-2022 10:18 PM
It just means I know when to ask the experts 😁
on 21-01-2022 10:00 PM
Aha, you are over qualified! 🙂
on 21-01-2022 09:53 PM
Thanks, really appreciated.
Must admit, I presumed that the upgrade to Fibre65 would have initiated a complete reset
Can't say it's the most customer friendly requirement to have to switch off for 30mins when the upgrade happens overnight - who would know or maybe I missed it somewhere ?
I didn't consider it and I've got a degree in electrical and electronic engineering!!!
on 21-01-2022 09:38 PM
The router sync speed may not have been in sync with the DSLAM sync speed, if you see what I mean! 😉
on 21-01-2022 09:30 PM
Switched the router off for 45mins.
Router resynched at 49.7mpbs but throughput is now 47.1mpbs - 10mpbs higher.
martswain you are a star.
But that is a bit ridiculous that the router synch increased with Fibre65 but the throughput was "remembered" from the old Fibre35 setting.
on 21-01-2022 08:35 PM
@Tim5230 try turning your router off for a full 30 minutes and then test again.
