on 07-06-2020 08:33 PM
hi there,
Like a lot of others, im getting the "whatsapp can't connect to WiFi, switch to mobile data" push notification.
Is there a fix for this? Not that its a massive inconvenience but grudge using mobile data when in the house and connected to WiFi.
On a new phone, but was doing it on the previous one too and has been temperamental with it for about 5 months, its getting annoying haha.
on 10-06-2020 01:55 PM
Hi Gareexx
Thanks for checking this.
I can send a different router for testing to rule out any possible router issues. Would you like me to arrange this?
on 10-06-2020 01:18 PM
Sorry for the delay in replying.
I've checked homepage and even turned the whole thing off and it still isn't fixing the issue.
Cheers
on 10-06-2020 07:40 AM
Hi Gareexx
Apologies for the delay.
Have you logged into My Account to check if HomeSafe/KidsSafe has been switched on?
on 07-06-2020 09:31 PM
Check your Homesafe settings on the TT web site. Make sure it allows Social Media/ web chatsd/ stuff like that.
Fritz
