Why need Engineer visit?
zofbtb
Message 12 of 12
At a loss why an engineer visit is needed Never had this swapping ADSL and VDSL ISPs in the past. Doubly odd as I'm moving from First Utility VDSL (who use TT) to TT.
11 REPLIES 11
Message 1 of 12
Yes, all fine but would like old phone number back and it is only syncing at 40Mbps - see my other posts
Message 2 of 12
Hi zofbtb,
Ok thanks for the update. Is everything ok with the connection?
Message 3 of 12
Had the visit yesterday while I was at work (wife at home). Seems like the visit was just to test the socket after the changes in the cabinet were done.
Chris-TalkTalk
Message 4 of 12
Hi zofbtb,
Can you complete your Community Profile and we'll take a look at this for you
Message 5 of 12
@zofbtb  i will now wiat for a OCE to reply and see if they can tell u why as they have access to ur account on their system.
Might be some notes on the visit.
Hope that help Regards Joe
zofbtb
Message 6 of 12
No,that's why I'm asking here!
Message 7 of 12
@zofbtb  Did the enginner say why or what did they do on visit???
zofbtb
Message 8 of 12
Yes, engineer coming on 8th (2 days after First Utility ends). They couldn't tell me why it was necessary.
Message 9 of 12
@zofbtb sometimes it is down to a set up but talktalk should be able to tell u later this week why.
Do u have one booked yet as they would have told u why when booking one???
zofbtb
Message 10 of 12
VDSL = FTTC = "fibre"
First utility 40Mbps  -> TT 65 ISH Mbps
No change to cabinet or wiring required as in essence I'm only changing speed not provider.
hosay299
Message 11 of 12
@zofbtb  if u can fill in the rest of ur profile on here the oce will look at next week and let u know why.
To save yourself time, please make sure that your community profile includes your first & last names, broadband phone number & if possible an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:- Personal Profile > Personal Information
It could be a change at the green box in road. or something else.
Can i ask did u have Fibre before with First Utility???
a bite more info might help out more with why???
