on 04-06-2019 10:08 AM
I am having an issue to change the IP address on the router:
Hardware Version FAST5364 3.00
Software Version SG4K10001400t
GUI Version 1.152.6
when trying to change the IP there is red bar below the IP box with "invalid IP Address"
Could you please update the firmware?
is there a link where we can download the firmware?
thanks in advance
on 08-08-2019 08:45 AM
We are waiting for this at the moment. There was a small delay as we are waiting for one of our teams to sign off on their testing before this is deployed. Our devices teams are chasing this up at the moment.
on 07-08-2019 09:18 PM
Any news on that trial for the Alpha firmware? Would love to be part of it. New router is collecting dust and i am almost at the point of buying my own. Plugged it in just now in the case its a go.
on 22-07-2019 09:19 AM
We are hoping to start alpha trials of the new firmware at the beginning of August.
on 20-07-2019 05:41 PM
on 28-06-2019 09:39 AM
Hi Kina_Speed
Apologies for the delay.
There are no further updates at the moment. Once new firmware is available then this will be rolled out to all routers (Wifi hubs)
on 28-06-2019 09:13 AM
Hi @OCE_Karl
Is there any update on the firmware?
Is it working now for 10.1.10.x?
Al the best
Edson
on 06-06-2019 01:55 PM
Thanks,
I will wait.
until there I will have the Hub as main router, and use another router just to distribute the 10.x IPs connected via WAN port. IPs..
Please let me know when the update has been done..
Kina
on 06-06-2019 01:47 PM
OK, wondering if its because you are choosing a 10. IP, all mine were 192.168.10.x range.
I'll raise this with our device manager, but I think this is already fixed in the next update.
on 06-06-2019 12:13 PM
Hello @Karl-TalkTalk
On my end it does not work.
I tried many times with different IPs..
Kina
on 05-06-2019 10:26 AM
We have fed this back to the device manager.
When changing the IP range on my own hub I did get this error, but clicked apply anyway and the change went through.
on 04-06-2019 04:23 PM
I did with clip and on back-end factory reset.
none worked.
when i use ip
10.1.10.1 or 10.0.0.1
The last field shows as "Invalid IP Address"
If i change to 192.168.2.1
it works.
The thing is, I have plenty devices connected to my house, all of them as static IP, starting 10.
I can't change all of them..
Thanks again
Edson
on 04-06-2019 01:17 PM
try a pin reset of the router - hold a pin or paperclip in the reset hole at the back for 10 seconds and this will fully reset the router.
Set the router back up and retest.
on 04-06-2019 12:42 PM
I have seen it, but the ip changes is not working.
Please have look at the attachment.
IPv4 Pool End "Invalid IP Address"
the other fields are fine
Thanks in advance
Kina
on 04-06-2019 12:20 PM
Hi @Kina_Speed
I've update the router firmware for you now.
on 04-06-2019 11:11 AM
I have asked one of TalkTalk's OCEs to pick your thread up and upgrade it for you.
