on 13-06-2022 09:17 PM
Hi there
I need to set my wi-fi channel to a manual one (7) because Auto just results in clashes with neighbours on the same channel which causes conflicts and slow-down.
I can change the channel on my router easily (Sagem SG4K100136) but the next day, it reverts back to 1 or 6!
Previously, your guys had to disable this feature called "Wi-Fi Optimisation" manually at the TalkTalk end. That worked and it stayed on the right channel for ages, but now it's happening again.
Can you please disable wi-fi optimisation again for me permanently, so my channel stays on what I select?
It's a really silly bug. If we decide to manually change the channel, it should stay on that channel and it certainly should not need intervention from TT engineers!!! I see others have reported the same in posts like this one - Wi-FI Channel Moves Overnight Even Though Auto Not... - TalkTalk Help & Support
James
on 16-06-2022 09:31 AM
Working now, thanks
on 14-06-2022 09:19 AM
Hi James
No problem 🙂
I have also sent you a Private Message with a link to short survey.
Thanks again.
on 14-06-2022 09:18 AM
Super, thanks Debbie, I've set it to channel 5 and will monitor over the next 24hrs to check it sticks on there.
Appreciate you getting back to me so quickly, thank you
on 14-06-2022 06:38 AM
Hi James
Apologies for this.
I've switched the WIFI optimisation off. Please let us know how the connection compares.
on 13-06-2022 09:28 PM
@jimifield, NEVER display personal information details on the public forum pages!
All your details should be up to date for staff to read in your community forum profile.
The wi-fi optimisation can get triggered by a factory reset of the router or by the latest firmware, so unfortunately does require disabling again by staff.
on 13-06-2022 09:27 PM
New firmware has been rolling out for the Sagemcom recently, when new firmware installs it turns Wi-Fi Optimisation back on. The support team here will be able to switch it off for you again tomorrow.
on 13-06-2022 09:21 PM - last edited on 13-06-2022 09:24 PM by Gliwmaeden2
Line no. XXXX REMOVED FOR SECURITY REASONS
