Wi-Fi Firmware Update
SteveyMc
Message 7 of 7
Good Morning, I recently received a replacement Wi-Fi Hub and after eventually finding more time to further inspect the User Interface it appears the Firmware is old. It shows 'SG4K10001400t' TalkTalk 2017 so I'm wondering if it's possible to force through an Updated Version? Kind Regards, Steven.
6 REPLIES 6
SteveyMc
Message 1 of 7
Thanks Karl that's good to hear. I'll add the required ports from the games and interface menu list and hopefully that fixes his console. Thanks as always 😊👏👍
Message 2 of 7
UPnP option is not available in the interface for the current firmware but will be available in the next firmware version that is currently in the pipeline.
SteveyMc
Message 3 of 7
Hi @Debbie-TalkTalk  sorry to be a nuisance, but there appears to be No UPNP On/Off option in the updated user interface? Unfortunately at present my sons Xbox One Console will not connect online correctly. I could enter all ports manually, but upnp is so much easier and more practical. Kind regards, Steven.
Message 4 of 7
Hi Steven
Wow, thank you for your kind comments 🙂
SteveyMc
Message 5 of 7
Morning Debbie, that was impressively efficient thank you. Your assistance never fails to impress. Kindest regards, Steven. 👏👏🙌😊💫
Message 6 of 7
Hi Steven
I've now updated your router firmware.
