Wi-Fi Hub
pb0011
Message 3 of 3
Earlier in the week I had fibre installed and it's working fine.
Today I received my TalkTalk WiFi Hub.  I don't think I need this as I've already got my Eero Hub.
Can I send the TalkTalk WiFi Hub back?  Was it just sent in error?  Is everyone getting one?
Message 1 of 3
The Eero does not contain a modem & hence if you use it without either a separate modem or the WiFi hub, your fibre will not work.
Message 2 of 3
Hi pb0011
Did you already have a TalkTalk router? (not the eero)
