Wi-Fi Optimisation is enabled again
Message 5 of 5
My Sagemcom 5364 Wi-Fi hub has started changing channels again, making me suspect that WiFi Optimisation has got re-enabled again. Please can you check & disable it for me?
4 REPLIES 4
Message 1 of 5
No problem Keith, happy to help 🙂
Message 2 of 5
Thanks for doing that for me @Chris-TalkTalk and thanks for doing it so quickly as well.
Chris-TalkTalk
Message 3 of 5
Yes you were correct Keith, wifi optimisation had been re-enabled on your device so I've disabled it again.
Chris-TalkTalk
Message 4 of 5
I'll take a look at it now Keith and get back to you 🙂
