Wi-Fi - Sign-In Error - New Home Move
Jsleo
Message 5 of 5
I moved into a new house, moving over from my old property. The internet was installed and the engineer said it was working. Unfortunately when we try and use the internet it links to connectionerror.testingbb.com and it asks us to sign in, any help would be much appreciated because I can’t really work while it’s not working
4 REPLIES 4
Message 1 of 5
Thanks for the update. Can I just confirm, which router were you using (make and model) that wouldn't work?
Jsleo
Message 2 of 5
I’ve managed to fix it, my dad brought over an old sky router and it seems to work using that, so it must be the router that was the issue
Thank you for your quick responses
Skynet_TX
Message 3 of 5
Hi @Jsleo,
If the advice from @martswain does not get things working then this may be an issue at the TalkTalk end, sometimes when people move home the TalkTalk systems can need a bit of a nudge to get your account working properly at the new location.
martswain
Message 4 of 5
What service do you have ?
If it's over the phone line, is that working and does dialing 17070 get a readback of the correct number ?
How long have you been connected ?
If it is just today, have you received notification your service is live ?
Try powering down all equipment for 30 minutes.
