Wi-Fi optimisation technology
PurplePolly
Message 3 of 3
Please can Wi-Fi optimisation technology be turned off on my router. It is constantly defaulting to channel 6 which is the same as my neighbour and causing interference. I have tried manually changing the channel but it still keeps automatically overriding it.
Message 1 of 3
Hi PurplePolly
Apologies for this.
I have switched off the WIFI optimisation, please let us know how the connection compares.
Skynet_TX
Message 2 of 3
Hi @PurplePolly,
As long as you have the Sagemcom Wi-Fi Hub then the staff here will be able to disable this for you, they should hopefully be able to pick this up tomorrow.
