on 19-05-2021 10:51 AM
Hi, the wifi hub that I received in November as a replacement has failed with the same fault as the previous one, I have carried out all the tests to no avail and am now using my old router from 2014, seems like they don't make them like they used to?
Regards Davy h.
on 24-05-2021 07:09 AM
Hi Dave
That's great, thanks for letting us know 🙂
on 21-05-2021 12:52 PM
Hi Karl,
Hub arrived this morning and is working fine, thanks once again for your help. Will return old hub in bag supplied.
Regards Dave.
on 19-05-2021 01:24 PM
You're Welcome 🙂
on 19-05-2021 01:17 PM
Hi Karl,
Thanks for your quick response, I look forward to receiving it.
Regards Dave
on 19-05-2021 11:22 AM
i'll send out the other model Hub and a returns bag for the faulty one.
