on 14-04-2022 10:33 AM
We have had the same router from Talk Talk for a couple of years now and have noticed some strange behaviours. These have started to crop up with ever increasing frequency now so if anyone can identify a way to stop them that would be great.
Our TV is linked to the router via a wired connection. Occasionally while watching catch up TV (BBC iPlayer and the like) the programme just ceases and goes back to the Talk Talk tv menu. There is no attempt to buffer or any delay, its almost like pressing an off switch on your remote. This only seems to happen with streaming platforms and is not limited to any one platform. It seems as though the internet connection is cut so it reverts back to the menu. It is possible to go back into the streaming services almost immediately but your place is often lost.
Secondly I am getting many instances where devices that are already connected to the wireless WiFi suddenly have ample wifi signal but no internet connection. This is true when connecting through wifi range extenders (both ones that use the house power cables to communicate and ones that take their signal from the air) and standing next to the router itself. This is often deceptive as your device (e.g. iPhone) connects and says you have full signal but in reality anyone sending you web based communications are not getting through and should you try and send a message it fails. Often it can take a couple of hours for you to realise you have been unreachable.
There are also occasions where when you try and connect to the house wifi network it will try for a while and then declare you have the incorrect password and ask you to re-enter it. If you do it tries to connect again and then declares your password is incorrect. Needless to say it is not. If you leave the device for a while it often then manages to connect later automatically without having to input a password but then suffers from the lack of internet problem mentioned above.
Finally one of the ethernet ports on the back has spontaneously stopped working. Anything plugged in there cannot communicate with anything else.
According to the label on the back the router is a Sagemcom with a Device Ver.: FAST 5364-3. T8
To my knowledge the device has never had any software or firmware updates.
Any help gratefully received!
on 20-04-2022 06:34 AM
Hi Edward
Thanks for the Private Message. The router is on its way, please allow 24-48hrs for this to arrive.
Let us know how the connection compares with the replacement router.
on 19-04-2022 07:14 AM
Hi Edward
Sorry for the delay.
Please can you send me a Private Message to confirm the name on the account, I can then send the replacement router.
on 15-04-2022 02:04 PM
Hello Debbie,
Yes please.
Many thanks
on 15-04-2022 08:47 AM
Hi Edward
Would you like me to send a replacement router for testing?
on 14-04-2022 02:48 PM
That sounds like the router to me then. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
They aim to respond within 48 hours (Monday - Friday), but if more urgent you can always try the Service Centre. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk have responded to you, otherwise, this will just put you further down the queue.
on 14-04-2022 01:59 PM
Hello Keith, thanks for responding.
The light on the router gives a steady white light. No blinks or flashes.
on 14-04-2022 10:44 AM
What happens to the light on the front of the router when all of this happens?
